build a modbus client with lorawan and cellular | wisblock guide
Build a Modbus RTU client using WisBlock with RS‑485 sending data via LoRaWAN or NB‑IoT. Learn data flow, TTN setup, and Ubidots dashboards.
Cellular and LoRaWAN Modbus Client with RAK WisBlock and Blues Notecard
Modbus is one of the most widely used communication protocols in industrial automation due to its simplicity, reliability, and long-standing adoption. Built on the RS-485 physical layer, it enables stable data exchange over long distances, making it suitable for connecting sensors, meters, and industrial controllers in demanding environments.
As industrial systems increasingly require remote monitoring and analytics, securely transmitting Modbus data to cloud platforms becomes essential. IoT technologies such as LoRaWAN and cellular networks provide scalable and cost-effective connectivity, enabling industrial data to be collected, visualized, and analyzed in real time from remote locations.
This tutorial replicates a project originally developed by Blues Wireless and extends it using RAK WisBlock modular hardware. A button and LED are included for interface functionality. By the end of this guide, you will be able to transmit it wirelessly using LoRaWAN or NB-IoT.
KEY TAKEAWAYS
  • Modular hardware simplifies the transition from prototype testing to enclosure-ready industrial deployment.
  • Power stability directly affects cellular reliability; insufficient current can cause transmission
  • Payload decoding determines whether cloud dashboards display meaningful Modbus register values.
  • Local Modbus emulation accelerates development before integrating real industrial equipment.
  • Connectivity choice depends on available infrastructure and account configuration.
  • Firmware flexibility enables adaptation to different Modbus register maps and devices.
  • Modbus RTU A binary serial communication protocol that utilizes CRC-16 error checking.
  • RS-485 A differential signaling standard for serial communication over twisted-pair cables, supporting distances of up to 1200 meters.
  • LoRaWAN Uplink A transmission from the RAK4631 to The Things Network (TTN) via the RAK7268V2 WisGate Edge gateway.
  • Cellular NB-IoT A low-power wide-area cellular standard designed for small, infrequent payloads.
  • Payload Decoding The process of converting raw binary uplink frames into structured JSON for cloud platforms.
Use Cases
This architecture is ideal for industrial environments where Modbus RTU devices require remote monitoring over wireless networks. The following scenarios illustrate direct applications of this setup without the need for firmware redesign; only the register map needs to be adjusted to match the target device.
  • Industrial Monitoring: Read process variables such as temperature, pressure, or flow rate from PLCs and sensors connected via RS-485.
The RAK5802 manages the physical layer while the RAK4631 polls registers at configurable intervals and forwards data to Ubidots.
  • Energy Metering: Retrieve consumption data from Modbus-compatible energy meters located in electrical panels or distribution boards. LoRaWAN is particularly effective in this context, allowing for coverage of meters distributed across a facility within gateway range.
For meters in isolated locations without local network infrastructure, cellular connectivity via the Blues Notecard is a suitable alternative.
  • Remote Equipment Diagnostics: Monitor operational status registers from pumps, drives, or HVAC controllers in remote or hard-to-access installations.
The IP67-rated Unify Enclosure and LiPo battery facilitate deployment in outdoor or space-constrained environments where periodic Modbus polling is adequate.
System Design Overview
Smart Parking Lot Help Request Solution
The goal of this project is to present a ready-to-use product for implementation in an industrial setting. The reference project uses Adafruit components and retrieves Modbus signals from a locally emulated server using Pymodbus.
The implementation is extended to create a final product capable of receiving data from any device connected via the Modbus protocol. Testing can be performed using another circuit or a Raspberry Pi to emulate the Modbus server.
Integration with WisBlock modular hardware addresses the limitations of the prototype by enabling a cleaner configuration and enclosure-ready deployment.
The original version did not utilize an IoT platform for visualization; this implementation incorporates Ubidots to provide real-time monitoring and an improved user experience. Finally, LoRaWAN communication is included as an optional connectivity method, offering users more connectivity options.
Hardware Requirements
Necessary Hardware
Figure 2: Required Hardware Components
Gateway
Back-End Services
Hardware Assembly and RS-485 Wiring
The hardware adopts a modular approach provided by WisBlock. The complete firmware is developed and available in the RAKwireless Tutorial GitHub for Modbus Client, and the IoT data visualization platforms are cloud-ready. The implementation replicates the project developed by Blues Wireless using JSON data to access the information.
  1. Insert the WisBlock Core (RAK4631) into the core slot of the RAK19001 baseboard. Other compatible cores are available from the RAKwireless WisBlock Base Boards.
  2. Install the RAK5802 module into an available IO slot on the RAK19001 baseboard.
  3. Connect the Blues Notecard via the WisBlock Blues Carrier Module, and insert it into an IO slot on the baseboard.
  4. Mount the assembled hardware inside the Unify Enclosure IP67 150 x 100 x 45 mm for deployment.
Final project installation view
IMPORTANT
The Blues Notecard requires a peak current of 2 A to send data. The VDD pin of the WisBlock cannot provide this current, so it is recommended to use a battery or connect an additional USB cable to the Notecard during your project testing.
RS-485 Deployment Notes
For reliable Modbus RTU communication, use twisted-pair shielded cable and maintain a common ground reference between connected devices. Route communication lines away from high-voltage or high-current wiring to reduce electrical noise.
Improper termination, grounding, or shielding can lead to CRC errors, intermittent timeouts, or unstable Modbus communication even when firmware settings are correctly configured.
Blues Hardware Assembly
After completing the instructions outlined in the hardware configuration and uploading the code provided by Blues on GitHub to the notecard, the final assembly is shown in the image below:
Final Result BluesWireless Version
Firmware Development and Configuration
The code can be downloaded from the RAKWireless Modbus Client Code Repository. It was developed using Visual Studio Code and PlatformIO, which are two widely used tools for programming firmware.
In case the libraries are not available on Platform IO, you can find them from the following sources:
If you need more information about how to configure and code your WisBlock setup with Platform IO, check the following guide for Setting up WisBlock on PlatformIO.
Connectivity Selection: LoRaWAN or Cellular
This project supports two wireless paths. The right choice depends on your site infrastructure and power constraints, not firmware capability, since both options use the same Modbus client logic on the RAK4631.
Use LoRaWAN when:
  • A LoRaWAN gateway, such as the RAK7268V2 WisGate Edge, is already deployed and reachable from the installation site
  • The device transmits small payloads at periodic intervals (Modbus register polling)
  • Power budget is limited, and the device runs on a LiPo battery without frequent charging
Use Cellular (Blues Notecard) when:
  • No LoRaWAN gateway is available or planned at the site
  • The installation requires independent wide-area connectivity without local network infrastructure
  • The site has reliable NB-IoT, LTE-M, or CAT-1 coverage supported by the Blues Notecard variant for your region
What does not change between paths:
  • Modbus RTU communication over RS-485 via the RAK5802
  • Register polling logic in the RAK4631 firmware
  • Data visualization in Ubidots
The connectivity decision affects gateway provisioning, Notehub or TTN account configuration, and power supply requirements. Both paths are covered in the sections below.
Cloud Integration and Data Flow
This section explains how Modbus data from the RAK4631 is transmitted to the cloud using either LoRaWAN or cellular connectivity. Each path requires proper network configuration and decoding to ensure that register values are accurately displayed in Ubidots.
End-to-End Data Flow Architecture
This project supports two cloud paths:
LoRaWAN
LoRaWAN Data Flow
Cellular
Cellular Data Flow
For LoRaWAN, TTN applies the payload decoder and forwards the structured JSON to Ubidots via a webhook. For cellular connection, the Blues Notecard sends structured data to Notehub, which then routes it to Ubidots
Authentication operates independently at each layer:
  • LoRaWAN devices authenticate to TTN using Over-The-Air Activation (OTAA).
  • TTN employs a Ubidots API token for webhook delivery.
  • The Notecard authenticates to Notehub using its device UID.
The firmware reads Modbus registers and formats the payload. TTN or Notehub manage routing and delivery, while Ubidots stores and visualizes the resulting data.
LoRaWAN Configuration (TTN)
The process of communicating with end devices via LoRaWAN networks can be accomplished through a public network like Helium or by setting up your network using a gateway for LoRaWAN. In this instance, configure the second option. For this process, you will need:
This process is straightforward and can be completed in just a few minutes. For a step-by-step configuration guide, refer to the How to Connect RAK Gateways to TTN v3 via UDP guide.
TTN Payload Decoder
async function formatPayload(args){
    var ubidots_payload = {};
    // Log received data for debugging purposes:
    // console.log(JSON.stringify(args));
    // Get RSSI and SNR variables using gateways data:
    var gateways = args['uplink_message']['rx_metadata'];
    for (const i in gateways) {
      // Get gateway EUI and name
      var gw = gateways[i];
      var gw_eui = gw['gateway_ids']['eui'];
      var gw_id = gw['gateway_ids']['gateway_id'];
      // Build RSSI and SNR variables
      ubidots_payload['rssi-' + gw_id] = {
        "value": gw['rssi'],
        "context": {
          "channel_index": gw['channel_index'],
          "channel_rssi": gw['channel_rssi'],
          "gw_eui": gw_eui,
          "gw_id": gw_id,
          "uplink_token": gw['uplink_token']
      ubidots_payload['snr-' + gw_id] = gw['snr'];
    // Get Fcnt and Port variables:
    ubidots_payload['f_cnt'] = args['uplink_message']['f_cnt'];
    ubidots_payload['f_port'] = args['uplink_message']['f_port'];
    // Get uplink's timestamp
    ubidots_payload['timestamp'] = new Date(args['uplink_message']['received_at']).getTime();
    // If you're already decoding in TTS using payload formatters,
    // then uncomment the following line to use "uplink_message.decoded_payload".
    // PROTIP: Make sure the incoming decoded payload is an Ubidots-compatible JSON (See https://ubidots.com/docs/hw/#sending-data)
    // var decoded_payload = args['uplink_message']['decoded_payload'];
    // By default, this plugin uses "uplink_message.frm_payload" and sends it to the decoding function "decodeUplink".
    // For more vendor-specific decoders, check out https://github.com/TheThingsNetwork/lorawan-devices/tree/master/vendor
    let bytes =  Buffer.from(args['uplink_message']['frm_payload'], 'base64');
    var decoded_payload = decodeUplink(bytes)['data'];
    // Merge decoded payload into Ubidots payload
    Object.assign(ubidots_payload, decoded_payload);
    return ubidots_payload
  function decodeUplink(bytes) {
    // Decoder for the RAK1906 WisBlock Environmental Sensor (https://store.rakwireless.com/products/rak1906-bme680-environment-sensor)
    var decoded = {};
    if (bytes[0] == 1) {
        // If received data is of Environment Monitoring type
        decoded.holding_register = (bytes[0] << 8 | (bytes[1]));
        decoded.input_register = (bytes[2] << 8 | (bytes[3]));
        decoded.coil_value = (bytes[4]);
    return {"data": decoded};
  module.exports = { formatPayload };
Cellular Configuration (Blues Notecard & Notehub)
Create an account on the Notehub page and then create a new project. For a detailed guide, you can review the Blues documentation to see the process step by step.
Blues Payload Decoder
    "coil": {"value": body.coil},
    "holdingRegister": {"value": body.holdingRegister},
    "inputRegister": {"value": body.inputRegister}
Ubidots Connection
The Blues Accelerator executes business logic through Notehub and the Notecard. While effective, this design makes it harder to scale to other networks and can be limiting for users who need a more visual, user-friendly way to access data.
To address this, Ubidots is used to visualize data collected by the WisBlock client from a Modbus server. Ubidots provides dashboards that allow users to easily monitor and interpret the collected values.
Using the PyModbus library, a server is emulated with:
  • 100 coils
  • 100 discrete inputs
  • 100 holding registers
  • 100 input registers.
The firmware provides functions to access all registers and inputs. For demonstration, a coil, a holding register, and an input register are read. These values are initialized to 0, 66, and 33. After the data is read, the final result appears in Ubidots, as shown in the figure below.
Visualizing data
The final solution deployed and working is presented in the following image:
Final Result
Deployment Considerations
  • A Raspberry Pi running Pymodbus emulates a Modbus server that provides register data for testing and cloud transmission.
  • The implementation can be used with real Modbus-compatible devices by adjusting the firmware to match the target device’s register map.
Strengths of Working with WisBlock
Comparison RAKwireless vs BluesWireless
  • Modular Design: Easy and fast to set up thanks to WisBlock’s plug-and-play modular architecture.
  • Clean & Professional: Results in a polished and compact final product with minimal assembly.
  • Developer-Friendly Firmware: Compatible with Arduino and PlatformIO; no need for complex IDEs.
  • Multi-Network Communication: Supports LoRaWAN and cellular (NB-IoT, LTE-M, CAT-1) connectivity.
  • Quick Integration with Dashboards: Easily connected to IoT platforms; no advanced front-end/backend coding required.
  • Stock Notice: Some components used in Blues' reference solution may no longer be available.
Summary
RAK WisBlock offers a flexible modular hardware solution for industrial IoT projects, enabling integration of Modbus devices with cloud platforms. Using the RAK4631 WisBlock Core, RS-485 communication, and the Blues Notecard, the system reliably collects Modbus data and transmits it wirelessly via LoRaWAN or cellular networks.
This architecture allows industrial devices to connect to cloud services such as TTN, Notehub, and Ubidots, supporting real-time monitoring, visualization, and data analysis without custom PCB development. Its modular design and prebuilt firmware accelerate deployment, while Arduino and PlatformIO compatibility ensures a developer-friendly workflow.
FAQs
Why is my RAK4631 not receiving any Modbus data over RS-485?
The RAK4631 WisBlock Core operates as a Modbus RTU client over RS-485. Communication requires matching serial parameters, including baud rate, parity, and stop bits. Incorrect settings can cause repeated timeouts or no response.
The firmware must also use the correct slave address and function code (0x01 for coils, 0x03 for holding registers, 0x04 for input registers). Always verify wiring, serial configuration, slave ID, and register type before assuming firmware failure.
Why do I get timeouts or intermittent Modbus communication?
Timeouts usually indicate that the Modbus server did not respond within the configured polling window. Causes include incorrect slave address, serial mismatch, or electrical noise on the RS-485 bus.
Each Modbus RTU frame contains a CRC-16 checksum. If validation fails, the frame is discarded. Intermittent communication often results from wiring issues, missing termination, or unstable grounding.
Why are my Modbus register values always zero or incorrect?
Incorrect values often result from polling the wrong register address or using the wrong function code. For example, reading a holding register with a coil function will return unexpected data.
In development, a Raspberry Pi running Pymodbus may initialize registers to default values such as 0, which appear valid but misleading. Multi-byte values must be interpreted consistently. Confirm the register map, polling interval, and register type configuration.
Why does the Blues Notecard reset or fail during cellular transmission?
The Blues Notecard can draw up to 2 A peak current when transmitting over cellular networks. The WisBlock VDD pin cannot supply this current, which may cause resets or failed transmissions.
Use a LiPo battery or a dedicated USB source during testing and deployment. This is an electrical limitation, not a firmware issue, and ensures reliable NB-IoT or LTE-M communication.
My device joins TTN but no data appears in Ubidots. What should I check?
If the RAK7268V2 WisGate Edge forwards data to TTN but Ubidots shows no updates, the issue is usually decoder-related. The TTN payload decoder must correctly parse the raw frm_payload and output properly structured JSON fields.
If register values are not decoded correctly, Ubidots will not display meaningful variables. Verify that the correct decoder is active, confirm the expected FPort is used, and ensure that decoded fields match Ubidots variable naming. Always validate the raw uplink payload in TTN before adjusting cloud configuration.
When should I use LoRaWAN versus cellular in this architecture?
LoRaWAN is appropriate when a gateway like RAK7268V2 WisGate Edge is available, supporting low-power, periodic transmission. Cellular via the Blues Notecard is better suited for locations without LoRaWAN coverage or when independent wide-area connectivity is required.
LoRaWAN requires proper decoder configuration and network registration, while cellular requires stable power and Notehub provisioning. The decision depends on infrastructure availability, power budget, and data transmission frequency rather than firmware capability.
Harold Duarte
  • Version 1 - Cellular and LoRaWAN Modbus Client with RAK WisBlock and Blues Notecard
    • Author: Harold Duarte
    • Reviewer: Karla Jimenez
    • Date Published: 30/03/2026
