how to connect rak gateways to chirpstack v3 via udp
This guide explains how to connect a RAK gateway to ChirpStack v3 using Packet Forwarder mode over the Semtech UDP GWMP protocol.
Before configuring the connection, make sure the following conditions are met:
  • A deployed ChirpStack v3 Network Server with Gateway Bridge configured for Semtech UDP.
  • Open the following ports on your ChirpStack server:
    • UDP 1700 for LoRaWAN packet forwarding
    • HTTP 8080 for ChirpStack Web UI access
  • RAK Gateway with internet access.
Register the Gateway in ChirpStack v3
This section provides step-by-step instructions for registering a RAK gateway in ChirpStack v3. For detailed instructions, refer to: How to Register a RAK Gateway in ChirpStack v3.
Configure the Gateway
  1. Log in to the gateway's web UI.
    图形用户界面, 文本, 应用程序 描述已自动生成
  2. Go to LoRa > Configuration, and set Work Mode to Packet forwarder.
    Set Work Mode to Packet forwarder
  3. In the Protocol field, click the dropdown. Then configure the following parameters.
    Configure the Protocol parameters
  • Protocol: Select Semtech UDP GWMP (default).
  • Server address: Enter the public IP address of your ChirpStack server, for example: 18.156.176.220
  • Server port up / Server port down: 1700
Verify Gateway Status
Once everything is set up correctly, your gateway will appear in the ChirpStack web interface under Gateways, with the Last seen field updating to a recent timestamp (e.g., “a few seconds ago”).
图形用户界面, 文本, 应用程序, 电子邮件
描述已自动生成
Troubleshooting
Issue Possible Cause Solution
Gateway not showing as online
  • Wrong server IP/port configured on gateway
  • Firewall blocks UDP 1700
  • Verify ChirpStack server IP/port is reachable from gateway
  • Ensure UDP port 1700 is open in firewall/security group
  GatewayEUI mismatch
  • Check gateway EUI in WebUI > Dashboard > Overview
  • Make sure the same EUI is used when registering the gateway in ChirpStack
  ChirpStack Gateway Bridge not bound to UDP 1700
  • Open /etc/chirpstack-gateway-bridge/chirpstack-gateway-bridge.toml
  • Confirm backend type is semtech_udp and listening on :1700
  Region mismatch Check chirpstack-network-server.toml and ensure the [network_server.band] parameter matches the hardware band of your gateway
ChirpStack Web UI not accessible Port 8080 blocked
  • Allow port 8080 through firewall/security group
  • Access via http://<your-server-ip>:8080
FAQs
1. Where can I find my Gateway EUI?
It's printed on the device labeled as “GWEUI”, or available in the WisGate Web UI under Dashboard > Overview.
2. Can I use a private IP for a server address?
Yes, but only if the gateway and server are on the same LAN. Use a public IP for Internet-based deployment.
  • Version 1 - How to Connect RAK Gateways to ChirpStack v3 via UDP
    • Date Published: 11/01/2025
