This guide explains how to connect a RAK gateway to ChirpStack v4 using Basics™ Station with LNS for secure TLS-based LoRaWAN® data communication.
Before configuring the connection, make sure the following conditions are met:
A deployed ChirpStack v4 Network Server
Open the following ports on your ChirpStack server:
TCP 3001 for LoRaWAN packet forwarding
HTTP 8080 for ChirpStack Web UI access
A RAK Gateway running WisGateOS 2, version 2.2.x or above
Must have internet access
Register the Gateway in ChirpStack v4
This section provides step-by-step instructions for registering a RAK gateway in ChirpStack v4. For detailed instructions, refer to: How to Register a RAK Gateway in ChirpStack v4
Configure the Gateway
Log in to the gateway's Web UI.
Go to LoRa > Configuration, and set Work Mode to Basics station.
Click Configure Basics Station server setup to expand the relevant settings panel. Configure the following parameters:
Basics Station Server Type: LNS Server
Server URL: Enter the WebSocket address of your ChirpStack server. Example: ws://18.156.176.220 (replace with your actual IP)
ws:// for non-encrypted WebSocket connections.
wss:// if you are using TLS, along with appropriate certificates
(tc.cert, tc.key, tc.trust).
Server Port: 3001
Authentication Mode: Authentication for the ChirpStack server. Select None for this setup.
Click Save changes to apply the configuration.
Once everything is set up correctly, your gateway should show as online in the ChirpStack web interface.
Troubleshooting
| Issue | Possible Cause | Solution |
| Gateway not showing as online | Gateway cannot reach ChirpStack server (network issue or wrong IP/port) |
| GatewayEUI mismatch |
| Wrong WebSocket protocol (ws:// vs wss://) |
| ChirpStack Web UI not accessible | Port 8080 blocked |
FAQs
1. Where can I find my Gateway EUI?
It's printed on the device labeled as “GWEUI”, or available in the WisGate Web UI under Dashboard > Overview.
2. What WebSocket URL format should I use for ChirpStack LNS?
Use ws://<IP> for unsecured connections (dev/test)
Use wss://<IP> for production (with TLS + certs)
3. Can I use a private IP for a server address?
Yes, if both server and gateway are on the same LAN. Otherwise, use a public IP.
4. What if my gateway firmware is older than WisGateOS 2.2.x?
You need to update your gateway to WisGateOS 2.2.x or above, as support for ChirpStack v4 is only available from this version onwards. You can check your current version and perform the upgrade via the gateway’s Web UI under System > Firmware. For detailed steps and download links, refer to the official upgrade guide: WisGateOS 2 – Firmware Upgrade Documentation.
Version 1 - How to Connect RAK Gateway to ChirpStack v4 Using Basics™
Station (LNS)
- Date Published: 10/30/2025
