how to connect rak lorawan gateway to actility (part 1)
This guide provides step-by-step instructions on how to set up and connect your RAK gateway to the Actility LoRaWAN® server. It specifically focuses on configuring the WisGate RAK7268V2 gateway, which acts as the bridge between your end devices and the Actility server.
In this tutorial series, the RAK2560 Sensor Hub will be used, connecting to the Actility LNS through the RAK7268V2 gateway. Additionally, this guide includes tips for debugging devices, troubleshooting, and instructions for forwarding sensor data for visualization.
ℹ️
INFO
This tutorial series is split into three parts:
Add a LoRaWAN Gateway in Actility Server
To get started, first register the gateway in Actility and verify the successful connection.
Actility uses Basic Station for gateway connections, which differs from the UDP-Forwarder or MQTT methods used by other LoRaWAN servers. As a result, the steps for establishing the connection slightly differ from those used with other systems.
Key Topics Covered:
Register the LoRaWAN Gateway in ThingPark
ThingPark is Actility’s IoT platform designed for deploying low-power, wide-area (LPWA) networks.
1. To access the platform, log in to the Actility ThingPark Admin Console. If you do not have an account, create one.
2. On the Admin Console Dashboard, click the “+” button under the BASE STATIONS tab to add your RAK gateway.
Actility DashboardFigure 1: Actility Dashboard
3. In the ADDING A BASE STATION prompt, select View More Manufacturers to expand the list and find additional gateway options.
Add a Base Station
Figure 2: Add a Base Station
4. In the Select Your Base Station Manufacturer window, locate and select RAKwireless. You can either scroll through the list manually or type RAK into the Type to search manufacturers field to quickly find it.
Select a Base Station Manufacturer
Figure 3: Select a Base Station Manufacturer
5. You will be redirected to the ADDING A BASE STATION page. In the Model selector, choose the gateway model that matches your device.
Select Base Station Information
Figure 4: Select Base Station Information
If your gateway is not listed, select a model based on the WisGateOS version your gateway is running.
Gateway OS Version
RAK Gateway Gateway Model Selection
WisGateOS 2
RAK7268V2 Edge Lite 2 WisGate Edge Pro (RAK7289 V2)
RAK7240V2 Edge Prime WisGate Edge Pro (RAK7289 V2)
RAK7285 Edge Ultra WisGate Edge Pro (RAK7289 V2)
RAK7289V2 Edge Pro WisGate Edge Pro (RAK7289 V2)
RAK7267 Soho Pro WisGate Edge Pro (RAK7289 V2)
WisGateOS
RAK7258 Edge Lite WisGate Edge Lite (RAK7258)
RAK7268 Edge Lite 2 WisGate Edge Lite (RAK7258)
RAK7240 Edge Prime WisGate Edge Prime (RAK7240)
RAK7289 Edge Pro WisGate Edge Max (RAK7249)
RAK7391 WisGate Connect WisGate Edge Lite (RAK7258)
In this guide, the RAK7268V2 running WisGateOS 2 is used; therefore, the appropriate selection is WisGate Edge Pro (RAK7289 V2).
6. Then, complete the remaining fields:
  • Name: Enter a name for your gateway.
  • LLR-UUID: This is the base station’s unique identifier and must follow this format 0016C0-XXXXXXXXXXXXXXXX, where ⁣XXXXXXXXXXXXXXXX is the gateway’s EUI.
The EUI can be found on the gateway’s label or on the Overview page in the gateway’s web UI.
Many regional options are available; choose the correct one for your deployment location. If you're unsure, refer to the LoRa Alliance Regional Parameters Plan or contact Actility support for guidance.
WisGateOS 2 Dashboard
Figure 5: WisGateOS 2 Dashboard
  • RF Region: Select the frequency band of your gateway from the drop-down menu.
IMPORTANT
If you are using a different LoRaWAN region, make sure to change it to the correct one. It is essential that all devices in your network use the same region to ensure proper communication and compatibility.
  • Additional Information: Optionally, enter any relevant notes or details about the gateway setup.
  • Position: Set the gateway’s physical location. This can be accomplished as follows:
    • Type the address into the Search field.
    • Click directly on the map to place the marker.
    • Enter the latitude and longitude coordinates should be done manually in the fields below the map.
QUICK TIP
If your gateway has a built-in GPS/GNSS module, you do not need to manually set the position. The gateway will automatically report its location to the Actility LoRaWAN server.
Here is an example setup for the gateway used:
Settings Details Selection/Entry
Model RAK7268V2 WisGate Edge Pro (RAK7289 V2)
Name   Edge V2
LRR-UUID Gateway EUI 0016C0-AC1F09FFFExxxxxx
RF-Region Test country Philippines AS923-3 Philippines 8-channel
Additional Information   Test Setup
Location Latitude/Longitude/Altitude xx.42152/xxx.00681/70
Set Base Station Location in Actility
Figure 6: Set Base Station Location in Actility
If you are using a different LoRaWAN region, change it to the correct one.
7. Once everything is set, click ADD to register the gateway in the Actility LoRaWAN server. A confirmation window will pop up. Click VIEW THE BASE STATION.
Confirm Base Station Location
Figure 7: Confirm Base Station Location
8. You will be redirected to the Dashboard of the registered gateway. Since the gateway is not set up yet, its status will appear as INITIALIZATION.
Actility Gateway Initialization
Figure 8: Actility LoRaWAN Gateway Initialization
Set Up LoRaWAN Gateway for Actility Integration
This section shows how to configure the RAK7268V2 gateway using its web UI. At this point, the gateway should already be connected to the internet via Wi-Fi, Ethernet, or cellular connectivity.
For detailed instructions on setting up the internet connection, refer to the WisGateOS 2 documentation.
  • Since the connection to the LoRaWAN server uses Basics Station, the LoRaWAN region is defined by the Actility server, not manually on the gateway.
  • During the connection process, the server automatically configures the gateway to use the correct LoRaWAN region.
1. To configure the gateway for the Actility LoRaWAN server, start by accessing the gateway’s web UI. For instructions on how to access it, refer to your specific RAK gateway’s documentation.
2. Once logged in, navigate to LoRa® Settings, then open the Configuration tab. By default, the gateway operates in built-in network server mode.
WisGateOS 2 Configuration Tab
Figure 9: WisGateOS 2 Configuration Tab
3. Change the Work Mode option to Basics Station. Then, click on Configure Basics Station Server Setup to proceed with the server configuration.
Select Basics Station in WisGateOS 2
Figure 10: Select Basics Station in WisGateOS 2
IMPORTANT
Before configuring the Basics Station settings, download the AmazonRootCA1.cer file. This certificate is required for the next step to establish a secure connection with the Actility LoRaWAN server.
4. The Actility LoRaWAN server uses the CUPS (Configuration and Update Server) protocol.
  • Select CUPS Server as the connection type.
  • Enter the Server URL: https://community.thingpark.io
  • Set the Server Port: 443
Configure Basics Station CUPS server
Figure 11: Configure Basics Station CUPS Server
5. In the Authentication Method section, select TLS Server Authentication.
Select Authentication Mode TLS
Figure 12: Select Authentication Mode TLS
6. Upload the previously downloaded AmazonRootCA1.cer file into the Trust (CA Certificate) field.
Upload the Amazon Certificate
Figure 13: Upload the Amazon Certificate
7. Once all the required fields are filled in, click Save Changes to apply and save the configuration.
Check LoRaWAN Gateway Connection in Actility
If the gateway successfully connects to the Actility LoRaWAN server, its status will change from INITIALIZATION to ACTIVE. However, since no devices are connected yet, no additional information will be displayed at this point.
Active Gateway Connection in Actility
Figure 14: Active Gateway Connection in Actility
Troubleshooting Gateway Connection
If the gateway does not show up as ACTIVE, verify the following settings in both the Actility console and the gateway configuration:
  • EUI Match: Ensure the EUI used in Actility matches the one retrieved from the gateway.
  • CUPS Settings: Verify the CUPS URL and port are set correctly in the gateway:
    • URL: https://community.thingpark.io
    • Port: 443
  • Internet Connection: Ensure the gateway has a stable internet connection and can reach the server.
To check connectivity, use the Network Utilities under the Diagnostics section of the gateway. Tools like Ping and Trace can help confirm server access.
WisGateOS 2 Ping Function
Figure 15: WisGateOS 2 Ping Function
WisGateOS 2 Trace Function
Figure 16: WisGateOS 2 Trace Function
Up Next: Connect LoRaWAN Sensor to Actility
Now that you've successfully connected your WisGate RAK7268V2 gateway to Actility, the next step is to connect the RAK2560 Sensor Hub to Actility's LNS in Part 2. Following that, Part 3 will guide you through forwarding sensor data for storage and visualization.
Bernd Giesecke
Bernd is an Electronics Engineer and Product Manager at RAKwireless with 23 years of experience in industrial and automotive hardware and software R&D. He has been supporting the Arduino open-source community since 2014.
  • Version 2 - How to Connect RAK LoRaWAN Gateway to Actility (Part 1)
    • Author: Bernd Giesecke
    • Reviewer: Alveiro Erazo & Harold Duarte
    • Date Published: 04/02/2025
  • Version 1 - How To Add RAK WisGate Edge Gateway V2 in ThingPark - Actility ThingPark Guide
    • Author: Todor Velev
    • Reviewer: Caryl Enanor
    • Date Published: 09/19/2024
