The Monogoto SIM card is the ideal choice for building reliable, scalable, and secure IoT applications. It provides cellular connectivity that is well-suited for linking your Internet of Things (IoT) devices, especially those that are mobile or deployed in remote areas.
As a trusted partner of Monogoto, RAKwireless proudly includes its SIM card as part of the company's product line. One of the key features of the Monogoto IoT SIM card is its ability to provide full management and visibility over your connected devices. With Monogoto's intuitive and user-friendly platform, you can easily manage your SIM cards and monitor your device connectivity. It also enables you to analyze your data usage in real-time.
The IoT SIM card supports multiple network technologies, including 2G, 3G, 4G, and LTE CAT-M1. In addition to its connectivity features, the Monogoto IoT SIM card provides global network resiliency, ensuring that your devices remain connected even during network outages or disruptions. This is particularly crucial for IoT applications where downtime can have serious consequences.
Monitoring of your SIM cards via a cloud-based platform.
Guaranteed SIM compatibility with any IoT device or smartphone with support for 2FF, 3FF and 4FF form factors.
Monogoto Secure IoT SIM works on 550+ cellular networks in 180 countries, offering all network technologies.
Technical Specifications
Parameter |
Value |
Form factor |
2FF/3FF/4FF |
Supported network technologies |
2G/3G/4G/LTE-M/NB-IoT |
Operating temperatures |
-40° C to 105° C |
Expected lifetime |
15 years at 85° C |
Read/Write cycles |
500,000 |
Voltage range |
1.62 V - 5.5 V |
SIM Card Form Factor Adjustability
Monogoto SIM cards have an adjustable form factor that can be changed to fit any device that accepts a SIM card: 2FF, 3FF, and 4FF.
Form Factor |
2FF Mini SIM |
3FF Micro SIM |
4FF Nano SIM |
Size (mm) |
25 x 15 x 0.76 |
15 x 12 x 0.76 |
12.3 x 8.8 x 0.67 |
Pricing
Data Package |
Price per Year |
Duration |
100 MB per month |
$11.50 |
1 year |
500 MB per month |
$40.00 |
1 year |
1 GB per month |
$71.50 |
1 year |
500 MB total |
$1.50 |
10 years |
📝 NOTE:
Activation Procedure
After purchasing a Monogoto IoT SIM card from our store, follow the activation procedure below to monitor and manage your SIM card. These steps will ensure you have access to Monogoto's platform and dashboard.
| 📝 NOTE: Do not register on the Monogoto portal prior to following the steps below. |
Start the SIM card activation process by sending an email to RAK support with your SIM card's ICCID number. The ICCID number can be found on the Monogoto SIM card and the plastic beneath the barcode, as shown in Figure 1.
After the team has completed the formalities, Monogoto will send you an email requesting that you complete your registration. Follow the link and create a password for your account.
You can use the Monogoto Hub and the dashboard once you have successfully created a password.
Dashboard
The Dashboard is the first section of the Monogoto Hub that appears once you log in, which is one of the primary methods for monitoring your things. This section allows you to monitor and collect data on the Things (SIMs) that you use with Monogoto.
The information shown in all of the Dashboard graphs and tables can be adjusted to fit your needs based on the currently selected Date Range and filters. To display information based on your selected Date Range or filter, press the GO button.
- Date Range: Allows you to change the period for displayed information on the Dashboard. The default period is the Last 30 days.
- Profile: Allows you to filter the information shown on the Dashboard by SIM profile. Note that it is normal to have only one profile.
- Network: Allows you to select which operator's information you would like to be displayed on the Dashboard graphs and tables.
- Group: Allows you to display information on the Dashboard for only your selected Thing Group.
General Information
General Information shows your Things (SIMs) activity, summarized for your selected period (Date Range).
- Active Things: Shows the total number of active Things (SIMs). This number should match your active SIM count.
- Data Usage in GB: Shows the total amount of data used in gigabytes.
- Networks in Use: Shows the total number of networks used.
- First-time registration: Shows the SIM Cards that are registered for the first time.
- Things Groups: Shows the Thing groups that have active Things within them.
Dashboard Tables and Graphs
The Dashboard has many tables and graphs that provide useful information about your Things (SIM) activity. You can learn more about each table and graph by selecting it below.
Daily Active Things
The Daily Active Things graph shows the number of active Things (SIMs) for your selected period (default is the Last 30 days). If you want to change the displayed period, refer to the information about filters.
Daily Active Things colors explained:
Red: Active Things
Blue: Active Things (activated for the first time)
Daily Data Usage
The Daily Data Usage graph shows the daily data usage of your Things (SIMs) in gigabytes for your selected period (default is the Last 30 days). If you want to change the displayed period, refer to the information about filters.
Top Profiles in Use
The Top Profiles in Use graph shows, in percentages, which SIM profiles have been used during your selected period (default is the Last 30 days). If you want to change the displayed period, refer to the information about filters.
Top Groups by Data Usage
The Top Groups by Data Usage graph shows data usage information per group for your selected period (default is the Last 30 days). If you want to change the displayed period, refer to the information about filters. It is normal to have only one Thing Group with active Things (SIMs).
Top Networks by Active Things
The Top Networks by Active Things table shows the top used operators, active SIMs, and data usage in these groups for your selected period (default is the Last 30 days). If you want to change the displayed period, refer to the information about filters.
Top Groups by Active Things
The Top Groups by Active Things table shows the top active operators used by your SIMs. This table and graph display information such as groups, Active Things, and Data Usage per Active Thing group for the selected period (default is the last 30 days). If you want to change the displayed period, refer to the information about filters. Thing Groups without active SIMs are not shown in this table.
Coverage
The table below shows the types of coverage available by country and operator, as well as some estimated availability dates.
Country |
Operator |
MCC |
MNC |
PLMN |
2G |
3G |
4G |
NB-IoT |
LTE-M |
LTE-CAT M1 Bands |
PSM |
eDRX |
Afghanistan |
AFW |
412 |
01 |
AFGAW |
Afghanistan |
Etisalat |
412 |
50 |
AFGEA |
Afghanistan |
MTN |
412 |
40 |
AFGAR |
Afghanistan |
Roshan |
412 |
20 |
AFGTD |
Albania |
AMC |
276 |
01 |
ALBAM |
Albania |
Eagle Mobile |
276 |
03 |
ALBEM |
Albania |
Vodafone Albania |
276 |
02 |
ALBVF |
12/31/2025 |
Algeria |
ATM Mobilis |
603 |
01 |
DZAA1 |
Algeria |
Djezzy |
603 |
02 |
DZAOT |
Algeria |
Wataniya Telecom Ooredoo |
603 |
03 |
DZAWT |
Andorra |
Mobiland |
213 |
03 |
ANDMA |
Anguilla |
Cable & Wireless |
365 |
840 |
AIACW |
Antigua and Barbuda |
Cable & Wireless |
344 |
920 |
ATGCW |
Argentina |
Claro |
722 |
310 |
ARGCM |
12/31/2023 |
12/31/2025 |
Argentina |
TMA |
722 |
07 |
ARGTM |
Argentina |
Personal |
722 |
34 |
ARGTP |
Armenia |
Telecom Armenia |
283 |
01 |
ARM01 |
Armenia |
UCOM (Orange) |
283 |
10 |
ARMOR |
Armenia |
Vivacell |
283 |
05 |
ARM05 |
Aruba |
Setar |
363 |
01 |
ABWSE |
Australia |
Vodafone |
505 |
03 |
AUSVF |
Sunset |
12/31/2023 |
Australia |
Telstra MobileNet |
505 |
01 |
AUSTA |
Sunset |
6/30/2024 |
3, 28 |
Austria |
A1 |
232 |
01 |
AUTPT |
12/31/2025 |
Austria |
Hutchison Drei Austria |
232 |
05 |
AUTCA |
Azerbaijan |
Azercell |
400 |
01 |
AZEAC |
Azerbaijan |
Azerfon LLC |
400 |
04 |
AZEAF |
Azerbaijan |
Bakcell GSM 2000 |
400 |
02 |
AZEBC |
Bahamas |
BTC The Bahamas Telecom Company |
364 |
39 |
BHSBH |
Bahamas |
NewCo |
364 |
49 |
BHSNC |
Bahrain |
BHR Mobile Plus |
426 |
01 |
BHRBT |
Sunset |
Bahrain |
VIVA Bahrain |
426 |
04 |
BHRST |
Bahrain |
Zain BH |
426 |
02 |
BHRMV |
Sunset |
Bangladesh |
Banglalink |
470 |
03 |
BGDBL |
Bangladesh |
GrameenPhone |
470 |
01 |
BGDGP |
12/31/2025 |
12/31/2026 |
Bangladesh |
Robi |
470 |
02 |
BGDAK |
Bangladesh |
Airtel (Bangladesh) |
470 |
07 |
BGDWT |
Barbados |
Cable & Wireless |
342 |
600 |
BRBCW |
Belarus |
BEST |
257 |
04 |
BLRBT |
Belarus |
MTS |
257 |
02 |
BLR02 |
Belarus |
A1 (VELCOM) |
257 |
01 |
BLRMD |
Belgium |
Base |
206 |
20 |
BELKO |
9/30/2024 |
Belgium |
Orange |
206 |
10 |
BELMO |
12/31/2030 |
12/31/2025 |
20 |
Belgium |
Proximus |
206 |
01 |
BELTB |
Benin |
Etisalat Benin S.A |
616 |
02 |
BEN02 |
Benin |
MTN Benin |
616 |
03 |
BENSP |
Bermuda |
Bermuda Digital |
350 |
000 |
BMUBD |
Bolivia |
Telecel |
736 |
03 |
BOLTE |
Bolivia |
NuevaTel |
736 |
01 |
BOLNT |
Bosnia and Herzegovina |
BIH |
218 |
90 |
BIHPT |
HT Eronet |
218 |
03 |
BIHER |
m:tel |
218 |
05 |
BIHMS |
Botswana |
BTC |
652 |
04 |
BWABC |
Brazil |
Claro |
724 |
05 |
BRACL |
12/31/2023 |
12/31/2025 |
Brazil |
Oi |
724 |
16 |
BRABT |
Brazil |
Oi |
724 |
31 |
BRATM |
Brazil |
Tim Brazil |
724 |
04 |
BRACS |
Brazil |
Tim Brazil |
724 |
02 |
BRARN |
Brazil |
Tim Brazil |
724 |
03 |
BRASP |
Brazil |
VIVO |
724 |
23 |
BRATC |
Brazil |
VIVO |
724 |
10 |
BRAV1 |
Brazil |
VIVO |
724 |
06 |
BRAV2 |
Brazil |
VIVO |
724 |
11 |
BRAV3 |
British Virgin Islands |
Cable & Wireless |
348 |
170 |
VGBCW |
CCT Global Communications |
348 |
570 |
VGBCC |
Brunei Darussalam |
DSTCom |
528 |
11 |
BRNDS |
Sunset |
Bulgaria |
Telenor |
284 |
05 |
BGRCM |
Bulgaria |
M-Tel Gsm |
284 |
01 |
BGR01 |
12/31/2025 |
Bulgaria |
Vivacom |
284 |
03 |
BGRVA |
Burundi |
Smart |
642 |
07 |
BDIL1 |
Burundi |
U-COM |
642 |
82 |
BDITL |
Cambodia |
Cellcard |
456 |
01 |
KHMGM |
Cambodia |
Metfone |
456 |
08 |
KHMVC |
Cambodia |
Smart Axiata Co., Ltd |
456 |
02 |
KHMSM |
Cameroon |
MTN |
624 |
01 |
CMRMT |
Canada |
Bell Mobility inc. |
302 |
610 |
CANBM |
Sunset |
4, 12 |
Canada |
Rogers Wireless Inc |
302 |
720 |
CANRW |
Sunset |
4, 5, 12 |
Canada |
TELUS |
302 |
220 |
CANTS |
Sunset |
12 |
Cape Verde |
CVMovel |
625 |
01 |
CPVCV |
Cape Verde |
Unitel T+ |
625 |
02 |
CPVTM |
Cayman Islands |
Cable & Wireless |
346 |
140 |
CYMCW |
Chad |
Airtel |
622 |
01 |
TCDCT |
Chad |
Tigo |
622 |
03 |
TCDML |
Chile |
Claro |
730 |
03 |
CHLSM |
12/31/2023 |
12/31/2025 |
Chile |
Entel PCS |
730 |
01 |
CHLMV |
Chile |
Telefonica |
730 |
02 |
CHLTM |
China |
China Mobile |
460 |
00 |
CHNCT |
China |
China Unicom |
460 |
01 |
CHNCU |
Sunset |
Colombia |
Claro |
732 |
101 |
COLCM |
12/31/2023 |
12/31/2025 |
Colombia |
Colombia Telecomunications S.A. ESP |
732 |
123 |
COLTM |
Colombia |
OLA/Tigo |
732 |
111 |
COLCO |
Congo Democratic Rep of |
Orange DRC |
630 |
86 |
CODOR |
Orange DRC |
630 |
89 |
CODSA |
Vodacom Congo |
619 |
5 |
CODVC |
Congo Rep of |
MTN |
629 |
10 |
COGLB |
Costa Rica |
I.C.E. |
712 |
01 |
CRICR |
Costa Rica |
Telefonica |
712 |
04 |
CRITC |
Costa Rica |
CLARO Costa Rica |
712 |
03 |
CRICL |
12/31/2023 |
12/31/2025 |
Cote D'Ivoire |
Moov CI |
612 |
02 |
CIV02 |
Cote D'Ivoire |
MTN |
612 |
05 |
CIVTL |
Croatia |
Tele2 |
219 |
02 |
HRVT2 |
Croatia |
VIPnet |
219 |
10 |
HRVVI |
2025.12.31 |
Curacao |
Digicel Curacao & Bonaire |
362 |
69 |
ANTCT |
Curacao |
UTS |
362 |
91 |
ANTUT |
Cyprus |
CytaMobile |
280 |
01 |
CYPCT |
Cyprus |
EPIC |
280 |
10 |
CYPSC |
Cyprus |
PrimeTel |
280 |
20 |
CYPPT |
Czech Republic |
O2 |
230 |
02 |
CZEET |
Sunset |
Czech Republic |
Vodafone |
230 |
03 |
CZECM |
12/31/2025 |
Sunset |
Denmark |
Hi3G Access AB 2 |
238 |
06 |
DNKHU |
12/31/2025 |
Denmark |
TDK-Mobil |
238 |
01 |
DNKTD |
Sunset |
Denmark |
Telenor A/S |
238 |
02 |
DNKDM |
12/31/2025 |
Sunset |
20 |
Denmark |
Telia Mobile |
238 |
20 |
DNKIA |
12/31/2025 |
12/31/2025 |
Dominica |
Cable & Wireless |
366 |
110 |
DMACW |
Dominican Republic |
Claro Dominicana |
370 |
02 |
DOMCL |
12/31/2023 |
12/31/2025 |
Altice |
370 |
01 |
DOM01 |
Trilogy Dominicana S.A. |
370 |
04 |
DOMAC |
Ecuador |
Claro |
740 |
01 |
ECUPG |
12/31/2023 |
12/31/2025 |
Ecuador |
Telefonica |
740 |
00 |
ECUOT |
Egypt |
Etisalat |
602 |
03 |
EGYEM |
Egypt |
Orange Egypt |
602 |
01 |
EGYAR |
Egypt |
Vodafone Egypt |
602 |
02 |
EGYMS |
El Salvador |
Digicel |
706 |
02 |
SLVDC |
El Salvador |
Telemovil (Millicom) |
706 |
03 |
SLVTM |
Equatorial Guinea |
Green Com S.A |
627 |
03 |
GNQHT |
Estonia |
Elisa Eesti |
248 |
02 |
ESTRE |
Estonia |
Tele2 Eesti AS |
248 |
03 |
ESTRB |
12/31/2025 |
12/31/2023 |
Estonia |
Telia |
248 |
01 |
ESTEM |
12/31/2025 |
12/31/2023 |
Faroe Islands |
Faroese Telecom |
288 |
01 |
FROFT |
Faroe Islands |
Kall Vodafone |
288 |
02 |
FROKA |
Fiji |
Digicel Fiji and Nauru |
542 |
02 |
FJIDP |
Finland |
DNA |
244 |
12 |
FIN2G |
12/31/2025 |
12/31/2023 |
Finland |
Elisa |
244 |
05 |
FINRL |
12/31/2023 |
3, 8, 20 |
Finland |
GSM Aland |
244 |
14 |
FINAM |
12/31/2025 |
Finland |
Sonera |
244 |
91 |
FINTF |
12/31/2025 |
12/31/2023 |
France |
Bouygues Telecom |
208 |
20 |
FRAF3 |
France |
Free Mobile |
208 |
15 |
FRAFM |
France |
Orange |
208 |
01 |
FRAF1 |
12/31/2025 |
12/31/2028 |
20 |
France |
SFR |
208 |
10 |
FRAF2 |
French Polynesia |
Tikiphone |
547 |
20 |
FRATK |
French West Indies |
Digicel |
340 |
20 |
FRAF4 |
Orange |
340 |
01 |
GLP01 |
Gabon |
Airtel (Zain) |
628 |
03 |
GABCT |
Gambia |
Africell (Gambia) Ltd |
607 |
02 |
GMBAC |
Gambia |
Qcell |
607 |
04 |
GMBQC |
Georgia |
Beeline |
282 |
04 |
GEOMT |
Georgia |
GeoCell |
282 |
01 |
GEOGC |
Georgia |
Magti GSM |
282 |
02 |
GEOMA |
Germany |
O2 |
262 |
03 |
DEUE2 |
Sunset |
20 |
Germany |
Vodafone |
262 |
02 |
DEUD2 |
12/31/2025 |
Sunset |
Germany |
E-Plus |
262 |
99 |
DEUE1 |
Ghana |
Airtel |
620 |
06 |
GHAZN |
Ghana |
Mobitel |
620 |
03 |
GHAMT |
Ghana |
MTN |
620 |
01 |
GHASC |
Ghana |
Vodafone Ghana |
620 |
02 |
GHAGT |
Sunset |
Gibraltar |
Gibtel |
266 |
01 |
GIBGT |
Greece |
Vodafone |
202 |
05 |
GRCPF |
12/31/2025 |
Sunset |
Greece |
Wind Hellas |
202 |
10 |
GRCSH |
Sunset |
Greenland |
Telegreenland 900 |
290 |
01 |
GRLTG |
Grenada |
Cable & Wireless |
352 |
110 |
GRDCW |
Guatemala |
Comcel (Millicom) |
704 |
02 |
GTMCM |
Guatemala |
Sercom - CLARO |
704 |
01 |
GTMSC |
12/31/2024 |
12/31/2026 |
Guatemala |
Claro (Old TLF) |
704 |
03 |
GTMTG |
Guernsey |
Sure |
234 |
55 |
GBRGT |
Guernsey |
Airtel Vodafone |
234 |
03 |
GBRAJ |
Guinea |
Areeba/MTN-Guinea |
611 |
04 |
GINAG |
Guinea Bissau |
MTN |
632 |
02 |
GNBSB |
Guyana |
Digicel |
738 |
01 |
GUYUM |
Haiti |
ComCEL |
372 |
01 |
HTICL |
Sunset |
Sunset |
Honduras |
Celtel TIGO (Millicom) |
708 |
02 |
HND02 |
Honduras |
Claro |
708 |
001 |
HNDME |
Hong Kong |
CWHKT |
454 |
00 |
HKGTC |
Hong Kong |
H3G Hong Kong |
454 |
03 |
HKGH3 |
Sunset |
Hong Kong |
Peoples |
454 |
12 |
HKGPP |
Hong Kong |
SMC |
454 |
06 |
HKGSM |
Hong Kong |
PCCW |
454 |
19 |
HKGM3 |
Sunset |
Hungary |
Telenor |
216 |
01 |
HUNH1 |
Sunset |
Hungary |
Vodafone |
216 |
70 |
HUNVR |
12/31/2025 |
Sunset |
Iceland |
Nova |
274 |
11 |
ISLNO |
12/31/2025 |
Iceland |
Siminn |
274 |
01 |
ISLPS |
12/31/2024 |
12/31/2025 |
Iceland |
Vodafone |
274 |
02 |
ISLTL |
India |
Airtel (Andhra Pradesh) |
404 |
49 |
INDJH |
India |
Airtel (Dehli) |
404 |
10 |
INDAT |
India |
Airtel (Karnataka) |
404 |
45 |
INDJB |
India |
Airtel (Rajastan) |
404 |
70 |
INDH1 |
India |
Airtel (Tamil Nadu) |
404 |
94 |
INDA4 |
India |
Airtel Bihar |
405 |
52 |
IND12 |
India |
Airtel Chennai |
404 |
40 |
INDSC |
India |
Airtel Gujarat |
404 |
98 |
INDA3 |
India |
Airtel Haryana |
404 |
96 |
INDA5 |
India |
Airtel Himachal Pradesh |
404 |
03 |
INDBL |
India |
Airtel Kerala |
404 |
95 |
INDA7 |
India |
Airtel Kolkata |
404 |
31 |
INDMT |
India |
Airtel Madhya Pradesh |
404 |
93 |
INDA8 |
India |
Airtel Maharashtra & Goa |
404 |
90 |
INDA2 |
India |
Airtel Mumbai |
404 |
92 |
INDA1 |
12/1/2023 |
Sunset |
India |
Airtel Orissa |
405 |
53 |
IND11 |
India |
Airtel Punjab |
404 |
02 |
INDA9 |
India |
Airtel UP East |
405 |
54 |
IND10 |
India |
Airtel Uttar Pradesh West |
404 |
97 |
INDA6 |
India |
Idea Cellular Andhra Pradesh |
404 |
07 |
IND07 |
India |
Idea Cellular Bihar & Jharkhand |
405 |
70 |
INDIB |
India |
Idea Cellular Dehli |
404 |
04 |
INDID |
India |
Idea Cellular Gujarat |
404 |
24 |
INDBI |
India |
Idea Cellular Haryana |
404 |
12 |
INDEH |
India |
Idea Cellular Himachal Pradesh |
404 |
82 |
INDIH |
India |
Idea Cellular Karnataka |
404 |
44 |
INDSK |
India |
Idea Cellular Kerala |
404 |
19 |
INDEK |
India |
Idea Cellular Kolkata |
405 |
848 |
INDIK |
India |
Idea Cellular MADHYA PRADESH |
404 |
78 |
INDMP |
India |
Idea cellular Maharastra |
404 |
22 |
INDBO |
India |
Idea Cellular Mumbai |
405 |
799 |
INDIM |
India |
Idea Cellular Orissa |
405 |
850 |
INDIO |
India |
Idea Cellular Punjab |
404 |
14 |
INDSP |
India |
Idea Cellular Rajasthan |
404 |
87 |
INDIR |
India |
Idea Cellular Tamil Nadu & Chennai |
405 |
852 |
INDIT |
India |
Idea Cellular Uttar Pradesh West |
404 |
56 |
INDEU |
India |
Idea Cellular Uttarpradesh East |
404 |
89 |
INDIU |
India |
Vodafone India Limited |
404 |
20 |
INDHM |
Sunset |
India |
Vodafone Cellular Limited |
404 |
46 |
INDBK |
India |
404 |
43 |
INDBT |
India |
Vodafone East Limited |
404 |
30 |
INDCC |
India |
Vodafone - Dehli |
404 |
11 |
INDE1 |
India |
Vodafone West Ltd |
404 |
05 |
INDF1 |
India |
Idea Cellular West Bengal |
405 |
853 |
INDIW |
Indonesia |
Hutchison 3 |
510 |
89 |
IDN89 |
Indonesia |
Indosat |
510 |
01 |
IDNSL |
Indonesia |
XL |
510 |
11 |
IDNEX |
Sunset |
Sunset |
Indonesia |
Telkomsel |
510 |
10 |
IDNTS |
Sunset |
International Networks |
CBRS Private LTE 99974 |
999 |
74 |
LTE74 |
Iran |
Irancell |
432 |
35 |
IRNMI |
Iran |
MCI |
432 |
11 |
IRN11 |
Iran |
RighTel |
432 |
20 |
IRNTT |
Iraq |
Asiacell |
418 |
05 |
IRQAC |
Iraq |
Zain IQ |
418 |
20 |
IRQAT |
Iraq |
Korek Telecom |
418 |
40 |
IRQKK |
Ireland |
Digifone |
272 |
02 |
IRLDF |
Ireland |
H3G |
272 |
05 |
IRLH3 |
Ireland |
Meteor |
272 |
03 |
IRLME |
Ireland |
Vodafone |
272 |
01 |
IRLEC |
12/31/2025 |
Sunset |
Isle of Man |
MANX |
234 |
58 |
GBRMT |
Israel |
HOT mobile |
425 |
07 |
ISRMS |
12/31/2025 |
Israel |
IL Orange |
425 |
01 |
ISR01 |
12/31/2025 |
12/31/2025 |
Israel |
Pelephone |
425 |
03 |
ISRPL |
12/31/2025 |
Israel |
CBRS Private LTE 42599 |
425 |
99 |
LTE99 |
Italy |
Iliad Italy |
222 |
50 |
ITAFM |
Italy |
Telecom Italia |
222 |
01 |
ITASI |
12/31/2029 |
Sunset |
Italy |
Vodafone |
222 |
10 |
ITAOM |
12/31/2025 |
Sunset |
Italy |
Wind Tre |
222 |
99 |
ITAH3 |
Italy |
Wind Tre |
222 |
88 |
ITAWI |
Jamaica |
Cable and Wireless Jamaica Ltd |
338 |
180 |
JAMCW |
Jamaica |
Digicel |
338 |
050 |
JAMDC |
Japan |
Softbank |
440 |
20 |
JPNJP |
1/31/2024 |
1, 8 |
Jersey |
JT Gsm |
234 |
50 |
GBRJT |
Jordan |
Zain |
416 |
01 |
JORFL |
Jordan |
Umniah Mobile Company |
416 |
03 |
JORUM |
Kazakhstan |
Beeline |
401 |
01 |
KAZKT |
Kazakhstan |
Mobile Telecom-Service LLP |
401 |
77 |
KAZ77 |
Kenya |
Airtel |
639 |
03 |
KENKC |
Kenya |
Safaricom |
639 |
02 |
KENSA |
Kenya |
Telkom (Orange) |
639 |
07 |
KENTK |
Korea Republic of |
KT |
450 |
08 |
KORKF |
3 |
Korea Republic of |
SK Telecom |
450 |
05 |
KORSK |
Kosovo |
IPKO |
221 |
02 |
K0001 |
Kuwait |
STC |
419 |
04 |
KWTKT |
Kuwait |
Wataniya Telecom |
419 |
03 |
KWTNM |
Kuwait |
Zain |
419 |
02 |
KWTMT |
Kyrgyzstan |
MegaCom |
437 |
05 |
KGZMC |
Kyrgyzstan |
NURTelecom |
437 |
09 |
KGZNT |
Kyrgyzstan |
Sky Mobile |
437 |
01 |
KGZ01 |
Lao People's Democratic Republic |
BEELINE LAO |
457 |
08 |
LAOTL |
Latvia |
Bite |
247 |
05 |
LVABT |
Latvia |
Tele2 |
247 |
02 |
LVABC |
Latvia |
LMT Gsm |
247 |
01 |
LVALM |
12/31/2025 |
Lebanon |
touch |
415 |
03 |
LBNLC |
Liechtenstein |
Orange |
295 |
02 |
LIEVE |
Liechtenstein |
Telecom Liechtenstein |
295 |
05 |
LIEMK |
Lithuania |
Bite Gsm |
246 |
02 |
LTUMT |
12/31/2028 |
12/31/2025 |
Lithuania |
Omnitel |
246 |
01 |
LTUOM |
12/31/2025 |
Sunset |
Lithuania |
UAB Tele2 |
246 |
03 |
LTU03 |
Luxembourg |
Orange |
270 |
99 |
LUXVM |
12/31/2030 |
12/31/2025 |
Luxembourg |
POST |
270 |
01 |
LUXPT |
Sunset |
Luxembourg |
Tango |
270 |
77 |
LUXTG |
Macao |
CTM |
455 |
01 |
MACCT |
Macao |
Hutchison Htmcl |
455 |
03 |
MACHT |
Sunset |
Macedonia Republic of |
ONE DOO Skopje |
294 |
02 |
MKDCC |
Vip Operator |
294 |
03 |
MKDNO |
Makedonski Telekom |
294 |
01 |
MKDMM |
Sunset |
Madagascar |
Airtel |
646 |
01 |
MDGCO |
Malawi |
Airtel |
650 |
10 |
MWICT |
Malaysia |
Celcom |
502 |
19 |
MYSCC |
Sunset |
Malaysia |
Digi Telecom |
502 |
16 |
MYSMT |
Sunset |
Malaysia |
Maxis |
502 |
12 |
MYSBC |
Sunset |
Mali |
Orange Mali SA |
610 |
02 |
MLI02 |
Malta |
Go Mobile |
278 |
21 |
MLTGO |
Malta |
Melita Mobile Ltd. |
278 |
77 |
MLTMM |
Malta |
Epic |
278 |
01 |
MLTTL |
Mauritania |
Mauritel Mobiles |
609 |
10 |
MRTMM |
Mauritania |
Mattel |
609 |
01 |
MRTMT |
Mauritania |
Chinguitel |
609 |
02 |
MRTCH |
Mauritius |
Emtel |
617 |
10 |
MUSEM |
Mauritius |
Mahanagar Telephone MTML |
617 |
03 |
MUSMT |
Mauritius |
Orange Mauritius |
617 |
01 |
MUSCP |
Mexico |
Iusacell |
334 |
050 |
MEXIU |
Sunset |
Mexico |
Telcel |
334 |
020 |
MEXTL |
12/31/2024 |
12/31/2026 |
1, 4, 7 |
Mexico |
Telefónica Móviles México |
334 |
030 |
MEXMS |
Sunset |
Moldova Republic of |
Moldtelecom |
259 |
05 |
MDAUN |
ORANGE |
259 |
01 |
MDAVX |
Moldcell |
259 |
02 |
MDAMC |
Monaco |
Monaco Telecom |
212 |
10 |
MCOM2 |
Mongolia |
Unitel |
428 |
88 |
MNGMN |
Mongolia |
Mobicom |
428 |
99 |
MNGMC |
Montenegro |
M.tel |
297 |
03 |
MNEMT |
Montenegro |
Telenor |
297 |
01 |
MNEPM |
Montserrat |
Cable & Wireless |
354 |
860 |
MSRCW |
Morocco |
IAM |
604 |
01 |
MARM1 |
Morocco |
Orange Moroc (MediTel) |
604 |
00 |
MARMT |
Mozambique |
Mcel |
643 |
01 |
MOZ01 |
Myanmar |
Myanmar Posts and Telecommunications |
414 |
01 |
MMRPT |
Myanmar |
Ooreedo |
414 |
05 |
MMROM |
Myanmar |
Telenor Myanmar |
414 |
06 |
MMRTN |
12/31/2024 |
12/31/2025 |
Nepal |
Ncell |
429 |
02 |
NPLM2 |
Netherlands |
KPN Telecom |
204 |
08 |
NLDPT |
4/1/2025 |
Sunset |
20 |
Netherlands |
Vodafone |
204 |
04 |
NLDLT |
12/31/2025 |
Sunset |
20 |
New Zealand |
NZC |
530 |
24 |
NZLNH |
Sunset |
New Zealand |
Telecom Spark NZ |
530 |
05 |
NZLTM |
3, 28 |
New Zealand |
Vodafone New Zealand Ltd |
530 |
01 |
NZLBS |
Sunset |
3, 28 |
Nicaragua |
Telefonia Celular de Nicaragua |
710 |
300 |
NICMS |
Nicaragua |
Enitel |
710 |
21 |
NICEN |
12/31/2024 |
12/31/2026 |
Niger |
Airtel |
614 |
02 |
NERCT |
Nigeria |
Airtel Networks Limited |
621 |
20 |
NGAET |
Nigeria |
9mobile |
621 |
60 |
NGAEM |
Nigeria |
MTN-NG |
621 |
30 |
NGAMN |
Norway |
NetCom |
242 |
02 |
NORNC |
12/31/2025 |
Sunset |
Norway |
Telenor |
242 |
01 |
NORTM |
12/31/2025 |
Sunset |
20 |
Oman |
OMAN MOBILE |
422 |
02 |
OMNGT |
Oman |
Ooredoo |
422 |
03 |
OMNNT |
Pakistan |
Mobilink |
410 |
01 |
PAKMK |
Palestine |
Jawwal (Paltel) |
425 |
05 |
PSEJE |
Palestine |
Wataniya Palestine Mobile |
425 |
06 |
PSEWM |
Panama |
Cable & Wireless Panama |
714 |
01 |
PANCW |
Panama |
Claro |
714 |
03 |
PANCL |
12/31/2024 |
12/31/2026 |
Panama |
Digicel |
714 |
04 |
PANDC |
Sunset |
Panama |
TIGO |
714 |
020 |
PANMS |
Papua New Guinea |
Digicel PNG |
537 |
03 |
PNGDP |
Paraguay |
Claro |
744 |
02 |
PRYHT |
12/31/2024 |
12/31/2026 |
Paraguay |
Telecel (Millicom) |
744 |
04 |
PRYTC |
Peru |
Claro Peru |
716 |
10 |
PERTM |
12/31/2024 |
12/31/2026 |
Peru |
Telefonica |
716 |
06 |
PERMO |
Philippines |
Globe Telecom |
515 |
02 |
PHLGT |
Philippines |
Smart |
515 |
03 |
PHLSR |
Poland |
Orange |
260 |
03 |
POL03 |
12/31/2030 |
12/31/2025 |
Poland |
P4 |
260 |
06 |
POLP4 |
Poland |
Plus Gsm |
260 |
01 |
POLKM |
Portugal |
NOS |
268 |
03 |
PRTOP |
Portugal |
TMN |
268 |
06 |
PRTTM |
Portugal |
Vodafone |
268 |
01 |
PRTTL |
12/31/2025 |
Sunset |
Puerto Rico |
Puerto Rico Tele Company CLARO |
330 |
110 |
PRICL |
12/31/2023 |
12/31/2025 |
Qatar |
Ooredoo |
427 |
01 |
QATQT |
Qatar |
Vodafone |
427 |
02 |
QATB1 |
Reunion |
SFR |
647 |
10 |
FRARE |
Romania |
Orange Romania |
226 |
10 |
ROMMR |
12/31/2030 |
12/31/2025 |
20 |
Romania |
RCS-RDS Digimobil |
226 |
05 |
ROM05 |
Romania |
Vodafone |
226 |
01 |
ROMMF |
12/31/2025 |
Russia |
BeeLine |
250 |
99 |
RUSBD |
Russia |
MTS |
250 |
01 |
RUS01 |
Russia |
Tele2 |
250 |
20 |
RUST2 |
Rwanda |
Airtel Rwanda Limited |
635 |
14 |
RWAAR |
Rwanda |
635 |
13 |
RWATG |
Rwanda |
MTN |
635 |
10 |
RWAMN |
Saint Kitts and Nevis |
Cable & Wireless |
356 |
110 |
KNACW |
Saint Lucia |
Cable & Wireless |
358 |
110 |
LCACW |
Saint Vincent and the Grenadines |
Cable & Wireless |
360 |
110 |
VCTCW |
Saudi Arabia |
Mobily |
420 |
03 |
SAUET |
Saudi Arabia |
Zain MTC |
420 |
04 |
SAUZN |
Senegal |
Sentel GSM |
608 |
02 |
SENSG |
Serbia Republic of |
Yettel |
220 |
01 |
YUGMT |
Vip |
220 |
05 |
SRBNO |
12/31/2025 |
Singapore |
M1 |
525 |
03 |
SGPM1 |
Sunset |
Singapore |
SingTel Mobile |
525 |
01 |
SGPST |
Sunset |
Singapore |
StarHub |
525 |
05 |
SGPSH |
Sunset |
Sint Maarten |
TelCell |
362 |
51 |
ANTTC |
Sunset |
Slovakia |
Orange |
231 |
01 |
SVKGT |
12/31/2030 |
12/31/2025 |
Slovakia |
Telefonica Slovakia, s.r.o |
231 |
06 |
SVKO2 |
Slovenia |
Mobitel |
293 |
41 |
SVNMT |
Sunset |
Slovenia |
SI.Mobil |
293 |
40 |
SVNSM |
12/31/2025 |
Slovenia |
Telemach Mobil |
293 |
70 |
SVNVG |
South Africa |
MTN |
655 |
10 |
ZAFMN |
12/31/2025 |
South Africa |
Vodafone |
655 |
01 |
ZAFVC |
South Sudan |
MTN |
659 |
02 |
SSDMN |
Spain |
MasMovil |
214 |
04 |
ESPXF |
Spain |
Orange |
214 |
03 |
ESPRT |
12/31/2030 |
12/31/2025 |
3, 20 |
Spain |
Telefonica |
214 |
07 |
ESPTE |
12/31/2025 |
Spain |
Vodafone |
214 |
01 |
ESPAT |
12/31/2025 |
Sri Lanka |
Dialog Gsm |
413 |
02 |
LKADG |
Sunset |
Sri Lanka |
Etisalat |
413 |
03 |
LKACT |
Sri Lanka |
Mobitel |
413 |
01 |
LKA71 |
Sri Lanka |
Hutchison |
413 |
08 |
LKAHT |
Sudan |
MTN Sudan |
634 |
02 |
SDNBT |
Suriname |
Digicel |
746 |
03 |
SURDC |
Switzerland |
Salt Mobile (Orange) |
228 |
03 |
CHEOR |
Sunset |
Switzerland |
Sunrise |
228 |
02 |
CHEDX |
Sunset |
Switzerland |
Swisscom, Swissom FL |
228 |
01 |
CHEC1 |
Sunset |
12/31/2025 |
1, 3, 7, 20 |
Taiwan |
Chunghwa Telecom |
466 |
92 |
TWNLD |
Sunset |
6/1/2024 |
3 |
Taiwan |
Far EasTone |
466 |
01 |
TWNFE |
Sunset |
6/1/2024 |
Taiwan |
Taiwan Mobile |
466 |
97 |
TWNPC |
Sunset |
Tajikistan |
Babilon-Mobile |
436 |
04 |
TJKBM |
Tajikistan |
Indigo Gsm |
436 |
02 |
TJKIT |
Tajikistan |
Tacom |
436 |
05 |
TJK91 |
Tanzania United Republic of |
Airtel |
640 |
05 |
TZACT |
MIC Tanzania |
640 |
02 |
TZAMB |
Smart |
640 |
08 |
TZAYA |
Thailand |
dtac |
520 |
05 |
THADT |
12/31/2025 |
3, 8 |
Thailand |
DTAC |
520 |
18 |
THAWP |
Thailand |
Real Future |
520 |
04 |
THACA |
Thailand |
Real Future |
520 |
00 |
THACT |
Thailand |
AWN |
520 |
03 |
THAWN |
Togo |
Togo Cellulaire |
615 |
01 |
TGOTC |
Tonga |
Digicel Tonga |
539 |
88 |
TONDP |
Trinidad and Tobago |
Digicel |
374 |
130 |
TTODL |
Tunisia |
Ooredoo |
605 |
03 |
TUNTA |
Tunisia |
Orange |
605 |
01 |
TUNOR |
Turkey |
AVEA |
286 |
03 |
TURIS |
Turkey |
Turkcell |
286 |
01 |
TURTC |
Turkey |
Vodafone |
286 |
02 |
TURTS |
12/31/2025 |
Sunset |
Turks and Caicos Islands |
Cable & Wireless |
376 |
350 |
TCACW |
Uganda |
Airtel Uganda |
641 |
01 |
UGACE |
Uganda |
MTN |
641 |
10 |
UGAMN |
Uganda |
Orange Uganda Limited |
641 |
14 |
UGAOR |
Uganda |
Smart |
641 |
18 |
UGASU |
Ukraine |
Kyivstar |
255 |
03 |
UKRKS |
Ukraine |
Life:-) |
255 |
06 |
UKRAS |
Ukraine |
Vodafone (MTS) |
255 |
01 |
UKRUM |
United Arab Emirates |
Etisalat |
424 |
02 |
ARETC |
Sunset |
United Kingdom |
Hutchison 3G |
234 |
20 |
GBRHU |
United Kingdom |
O2 UK |
234 |
10 |
GBRCN |
20 |
United Kingdom |
Orange |
234 |
33 |
GBROR |
12/31/2025 |
Sunset |
United Kingdom |
Vodafone |
234 |
15 |
GBRVF |
12/31/2025 |
12/31/2023 |
United States |
AT&T |
310 |
410 |
USACG |
Sunset |
Sunset |
2, 4, 12 |
United States |
T-Mobile Denver |
310 |
260 |
USAW6 |
Sunset |
United States |
CBRS Private LTE 315010 |
315 |
010 |
LTE01 |
United States |
CBRS Private LTE 315011 |
315 |
011 |
LTE011 |
Uruguay |
Claro (CTI) |
748 |
10 |
URYAM |
12/31/2023 |
12/31/2025 |
Uzbekistan |
Beeline Uz |
434 |
04 |
UZBDU |
Vanuatu |
Digicel Vanuatu |
541 |
05 |
VUTDP |
Venezuela |
Movistar |
734 |
04 |
VENMS |
Vietnam |
Beeline Vietnam |
452 |
07 |
VNMBL |
Vietnam |
Viettel |
452 |
04 |
VNMVT |
Vietnam |
Vinaphone |
452 |
02 |
VNMVI |
Vietnam |
Vms Mobifon |
452 |
01 |
VNMMO |
Yemen |
Spacetel |
421 |
02 |
YEMSP |
Zambia |
MTN |
645 |
02 |
ZMB02 |
Zambia |
Airtel |
645 |
01 |
ZMBCE |
Zambia |
Zamtel |
645 |
03 |
ZMBCZ |
Zimbabwe |
NetOne |
648 |
01 |
ZWEN1 |
